Handset does not detect the sim card
Why my handset does not detect the sim card while the same sim card is detected on another handset
Esta é uma boa pergunta?
Hi,
Have you tried a different known working SIM card in your phone to see if it works?
If it works it may be a compatibility problem between your SIM card and your phone. Try replacing your SIM card with a new one and see if that solves your problem.
If it doesn't work you may have a faulty SIM card reader in your phone.
Esta resposta foi útil?
I tried different working SIM card but still shows same.. Now the fault must be on SIM card reader.. Is any way to fix the it??
Hi, As the card reader is mounted on the board you may need to take it to a reputable, professional phone repair service which has the expertise and tools necessary to do surface mount pcb component replacements.
Here is a video showing the dis-assembly of an Alcatel One Touch Idol 2. At 2:50 minutes into the video it starts to show the removal of the board on which the card reader is mounted.
I woke up and it said no sim card I didnt take the sim card out but ehen I did it was powered off and It had already said no sim card emergency calls only what will cause this
Hi, please can someone advise me, i bought a alcatel pixie 4, 5010x today, second hand. the shop, put their ee sim in. But mine comes up no sim, HELP
Hi it keep saying no SIM card but it is one in there help please
Do not buy this phone, you will have this problem. They are not very durable. If you drop the phone you will have this problem
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 20
Ao todo: 26,837
