Ir para o conteúdo principal
Informações de reparo para a segunda iteração do Aspire S7, o S7-392. Este é um notebook ultrabook premium de 13" fabricado pela Acer.
No Bootable Device Error after keyboard replacement
I have an Acer Aspire S7 and replaced a faulty keyboard. However I did not disconnect the battery during the replacement and may have corrupted something in the process. After the replacement, when I boot up the computer I get a "no available boot device" error and there are no drives found in the BIOS, indicating that it can't access the hard drive. Since these SSD's seem to be hot-swappable, I don't think I "wiped" the drive during dissembley, but I'm not sure.
Also, the battery doesn't function and doesn't register as charging.
Everything seems plugged in properly so I'm a little at a loss
My initial question what could I have potentially corrupted during the repair? How can I systematically determine what that thing is?
Thanks!
p.s. keyboard works great :P
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
My Acer S7 ultrabook some problem switch on (No bootablet please reset system) but will hold the button switch on back not have working
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ajkrell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 678
