Ir para o conteúdo principal
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
Samsung galaxy tab 2 10.1 Boot Loop
I know how to fix a boot loop, but not this on. So I have got a boot loop in my tab. I tried ASR, updates and clearing my data. Nothing. Is there anything else I can do?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Have you tried disconnecting the battery, holding the power button for 30 seconds to dissipate any residual power in the tablet, then reconnecting the battery and seeing if it starts normally.
Here is a link that shows how to replace the battery. It is useful as it shows how to open the tablet. It also shows the battery connector (with the red and blue wires) and how to remove it from the socket at 5:00 minutes into the video. The battery connector seems to be able to be accessed quite easily and as you are not replacing the battery, it should be able to be disconnected/reconnected without having to remove other cables, components or screws, except for a piece of tape, shown starting to be removed at 2:43 minutes into the video.
https://www.youtube.com/watch?v=Ow5T93uq...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Jake Latham será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 2,963
