Ir para o conteúdo principal
8.9" tablet, co-developed by Google and HTC. First released in November 2014, running Android 5.0 Lollipop.
29 Perguntas Visualizar todos
wifi keep on disconnected
my nexus 9 wifi is unstable it connected . surfing awhile then it will reconnect after that it will totally disconnected and searching for wifi.
and sometimes I turn off wifi and restart my tablet ,I turn on my wifi it will stay turning on...
may I know issit wifi antenna got issue? I hope its not the motherboard issue.
thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Not sure about your tablet if the following settings are available, but you may wish to check and see if changing them improves your WiFi performance.
Go to Menu > Settings > Wireless and Networks > WiFi > (tap the three dots? not sure of this for your tablet) Advanced.
1. WiFi Frequency band set it to 2.4MHz instead of 5MHZ or both.
2. Keep WiFi on during Sleep - set it to always if not set to this already.
3. WiFi Optimization - set to off
4. Network notification - set to off
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
AW HENG LOONG será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,379
