Ir para o conteúdo principal
Part of the Lenovo G Series of everyday laptops released in November 2012.
23 Perguntas Visualizar todos
Why my half of the screen turn pink in color
half of my screen turned into pink and blur.
Esta pergunta é pertinente?
Pontuação 0
1 dos comentários
What is the history of this laptop? Have you dropped it or damaged the hinges on it?
This can either be a faulty screen or bad connection between the LCD plug and the LCD (Not plugged in fully or correctly).
It can be other things that I don't know of as well.
por
Adicionar um comentário
1 Resposta
Solução escolhida
Rajesh Adapa connect an external monitor and see what that shows. If it is working good than you most likely have a bad LCD. If an external monitor displays the same errors, you are having issues with the GPU circuitry on your logicboard.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Rajesh Adapa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 2,938
