Ir para o conteúdo principal
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Perguntas Visualizar todos
power drops when disconnected from charger
Hi
a while ago I droped my iPod i water (with salt). After a some time it started to react but then froze.
I have now managed to take it apart, and have cleaned the logic board a little.
After putting it back together the navigating works again :) but only when the iPod is connected to my separate usb-charger :(
When I pull the plug the screen switches off, and when I reconnect to the charger, the iPod reboots.
When I switch it off while connected to charger, the display shows the "charging grafic".
Before I took it apart it only reacted to the hold-button, but the power didn't drop like that. Logic says I have made some mistake when reassembling, but it confuses me that all works with power from charger.
any suggestions?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Your battery is dead or not connected properly.
Try to open it up and reconnect the battery.
If that doesn't help your battery is dead.
Ps.
If you have a multimeter (or know someone working with electronics) you can check of it holds any charge at all.
Ps 2.
When dropped in salt water a lot of stuff can fail. But reading that it used to work before you opened it my guess is that you didn't connect it back properly.
Esta resposta foi útil?
Pontuação 1
5 comentários:
thanks rousp!
- the battery seemed to hold some charge before I took it apart, so I will go along with your guess.
When I disconnected the battery, I didn't find any release mechanisme so I just pulled the ribbon-cable from the socket. But that makes me uncertain about reconnecting: should some mechanisme be opened first?
por
Yes, there is a locking bar on the connector. Usually on the top. Use a spudger to release it and then lock it again.
That procedure is needed to reseat the ribbon cable properly. But I must admit that I always just pull them out like you did.. Don't know if it's a smart thing to do though...
In other words, I don't think your battery is connected properly. Open the iPod and reconnect it. Please accept the answer if it proves right.
por
thanks again I found the mechanisme, but same result :( I've ordered a new battery, and will let you know if that solves the problem.
por
Thanks, good luck!
por
update: my iPod is now playing my music-files with a fully charged battery :))) the diagnosis is still a bit uncertain, though: After incerting a new battery, the iPod went back to the state of partly malfunctioning as before it froze and I took it apart: it showed an almost empty battery imediatly after having showed fully charged. But it would allow me to sync it again. I then took it apart and rubbed the logicboard some more with a soft stick (wood). That seems to have done the trick. But to test it I will have to see if it now works with the old battery but that might never happen.
por
Adicionar a sua resposta
bjoern holst jespersen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 9
Duração total: 1,618
