Ir para o conteúdo principal
Um grande smartphone da LG, lançado no outono de 2014. O LG G3 (D855) possui uma tela IPS Quad HD e uma câmera de 13 megapixels.
SD Card Slot not working properly
As it says in the title. The SD Card slot in my LG G3 is not functioning properly. It will mount and then unmount the card repeatedly and endlessly. Is there any way to fix this or repair the slot?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Have you tried another microSD card? The microSD card slot may be physically damaged or burnt inside if it still doesn't work.
Esta resposta foi útil?
Pontuação 1
4 comentários:
I've tried 4 different sd cards and they all had the same result. I've also tried cleaning it some with isopropyl alcohol and canned air to no effect. No clue as to how it could have been damaged as it just randomly started doing it the one day.
por
Did you ever get this fixed, OP? I've been having the same issue for months now and I can't ignore it anymore
por
Unfortunately I was never able to get it fixed. I ended up getting a refurbished G4 for 200$.
por
Thanks for the answer! I've resigned myself to a new phone (V20) as well...
por
Adicionar a sua resposta
mitchellblu3 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 3,360
