Ir para o conteúdo principal
O smartphone Android Sony Xperia Z5 foi lançado em outubro de 2015. O Sony Xperia Z5 possui uma tela de 5,2 polegadas com 1080 x 1920 pixels, equipado com um processador Qualcomm Snapdragon 810, 3 GB de RAM e uma câmera traseira de 23 MP.
Sim stuck in slot
Sim card stuck in slot deep
Xperia z5
Not on the sim tray
Iv got that out
I didnt know what it was for
Esta é uma boa pergunta?
Pontuação 3
1 comentário
My sim card is stuck inside Th the phone still, I can't seem to get it out, I é tried everything lol I'm not good at this kinda stuff
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Last time this happened to me, I stabbed the sim with an exact knife and pulled out slowly. Took a try or two but worked
Esta resposta foi útil?
Pontuação 4
1 comentário:
Brother Robert thank u soo much bro. ur comment helped me and i successfully pulled out my sim. JazakALLAH !
por
If the phone doesn`t have a push/pull configurations, then the sim would`ve stucked inside a tight space. To remove the micro sim, you will need a small piece of metal that can slip into the micro sim slot and then push it outside so that it would go out. Don`t try to press it forward because it will just make it harder to get out. If you don`t want to damage your phone further, simply go to the nearest Sony center which will they will do it for you for a fee of their service.
Pontuação 3
Mine is stuck as well in th sim port but I've tried a needle, I've tried tapping my phone around but it's still stuck and Sony says that it isn't covered under manufacturing defect so they won't do anything. So I'm stuck with a phone that can't be used as a phone because the tray will only fit halfway in. Is there anything I can do?
Pontuação 1
This thread was really useful. If you look carefully you will note the there will be some space on the side of the card, as the SD slot is wider. I have successfully used a paper clip to take the SIM card out without much trouble.
>> Push an unwinded paper clip inside on the side of the SIM card and fish it out. <<
Pontuação 1
Adicionar a sua resposta
Kc será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 12,593
