Ir para o conteúdo principal
O HP Chromebook 14 é uma variante da linha Google Chromebook lançada em 11 de setembro de 2013. O número do modelo é 14-Q010DX.
Why is my screen blank?
I had some Chrome OS defective notices pop up all of a sudden. It required me to use the Chrome OS recovery utility to create a USB Recovery drive to re-install the OS. It worked, and things went back to normal...for a little while. Then the Chrome OS defective issue popped up and got fixed several more times, until finally...the screen would stay blank when the Chromebook was powered on. I could still hear the fan running, and see all the usual lights, like power on indicator light, etc.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Ultimately, purchasing a new 16GB SSD for $17 on ebay solved the problem and now the machine is running perfectly!
I didn't use the exact same brand that was in there, because this other one was the cheapest. Here's the title of the ebay posting I purchased the part from:
16GB SSD Hard Drive LSS-16L6G-HP 735314-001 HP 14-Q010NR Genuine (A01)
In the computer the part is mounted on the motherboard and underneath the motherboard, as you'll see when following one of the already available guides.
Esta resposta foi útil?
Pontuação 1
good.:) from'love heaven' thats my name
Pontuação 0
Adicionar a sua resposta
Stephen Jennings será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 1,470
