Ir para o conteúdo principal
A Black and Decker Air Station é um compressor de ar de 160 psi projetado para inflar diversos itens domésticos.
Air station quit working
I a ired up one tire then hooked my air station to another tire but the air station would not come on.I checked all I could check but it still would not come on.What can I do?Did the ac dc switch suddenly go bad?
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
My air station will not blow up my tires. It blows air when not attached to the tire. HELP
por
Adicionar um comentário
1 resposta
I just got me one of these at goodwill for $40 and I wish I had my money back! Your Air Station stopped working because the fuse blew just like mine did only the second time I used it. And guess what? I had to take it apart to get to the small fuse inside and this is a pain in the ass because you have to cut out the old fuse and solder in a new one.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Hi,
There's always a reason why a fuse blows, so don't be ssurprised if it happens again very soon.
Fuses blow because excess current is flowing through them due to a problem in the circuit that they're there to protect e.g. short circuit turns in the motor winding or a component that has changed value for whatever reason.
What is the model number of the device?
por
Adicionar a sua resposta
george m denison será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 31
Ao todo: 2,493
