Ir para o conteúdo principal
Also known as the GS70 Stealth, this 17" gaming laptop was released in summer 2013 by Micro-Star International. Identified by the model number MS-1772.
20 Perguntas Visualizar todos
Where can I order a replacement fan for the GPU?
My GPU fan is making extremely loud noises when it is running, (Basically, whenever my power cord is connected) and it sounds like the bearing is failing. I got one of the first models and I can't find a place to buy a replacement fan.
I live in the Netherlands.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Hi,
Have you tried Ebay.
Here is a link. If this is no good post your exact model number.
http://www.ebay.com/itm/New-for-MSI-GS70...
Esta resposta foi útil?
Pontuação 3
3 comentários:
Model number is: GS70 2OD-061NL or 9S7-177114-061
Those fans look quite a lot different from the once that are inside mine.
por
Hi, Can you see a 'part' or 'model' or any number on the fan or fan housing? If there is a number perhaps if you "Google" just the number you may have better luck.
por
I've found one. 90 Euro though if I include import costs. Guess it's better then buying a new Laptop. Thanks for your help
por
One of the websites I am using to find graphic card fan replacements is:
https://www.gpufanreplacement.com
Just search on this website or ask them via live chat to get your exact fan.
Pontuação 0
original https://www.amazon.com/dp/B07CWHDLXM
Pontuação 0
Adicionar a sua resposta
Eternal Genesis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 5,116
