Ir para o conteúdo principal
Repair and support information for the Asus ZenFone 6. It utilizes an Intel Atom 2580 processor. Was released 2014.
40 Perguntas Visualizar todos
Why is my phone need to use charger to access applications?
my phone just soaked by water today, and after i clean it or dry it, it still work!!!, at first the charging port is unusable, but it also work now. and now i get a new problem. if i didn't charge my phone, it cannot access all application inside of zenfone 6, can anyone solve this problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Antony,
It sounds like you're still dealing with the ongoing effects of water damage. In fact, you might still have moisture in your phone. As many community members can confirm, water damage can often show up hours or days after the initial incident. I'd recommend powering the phone down, pulling the battery, and taking care of any remaining moisture and residue.
You'll probably want to disassemble your phone and clean it before you power it up again. We don't have guides for the ZenFone 6 yet, but there are a few videos on YouTube that could prove helpful. Be sure to check out our Electronics Water Damage page for help taking care of the water damage. Hopefully, this will fix the problem and prevent anything worse from happening. Good luck!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Antony será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 91
