Ir para o conteúdo principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 Perguntas Visualizar todos
Why is my car making a grinding noise on right turns
My 2003 Nissan Altima is making a grinding sound on sharp right hand curves only? What is wrong with it ?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@cloudysbrat sounds like a bad CV joint but could be issues like wheel bearings etc. Check your CV joints for sure.
por
Adicionar um comentário
1 resposta
Solução escolhida
@cloudysbrat attached is a symptoms chart for your vehicle
and here is an excerpt from the manual about how to remove those driveshafts. If you are up for it, you can check and/or replace the CV joint.
Altima-driveshaft.pdf
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Kristy robinson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 225
