Ir para o conteúdo principal
Pergunta encerrada
Display Flex Cable Connectors
I make the procedure to clean up my display with clouding. In the disassembly i make a mistake and break the logical board connector and the flex cable, i know that's replacement for the flex cable but can i repair the logical board connector?
best regards
Alfonso
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hello, Alfonso -
It depends on two things:
1) If the connector pulled off of the board cleanly, without structural or mechanical damage.
2) if you have the skills to do surface-mount soldering, or know somebody who does. Probably needs a microscope, very steady hands, paste solder, and a hot-air soldering station.
It is a very challenging repair. Good luck!
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 89
