Ir para o conteúdo principal
The Huawei P8 Lite (Model: ALE-L21) announced April 2015, shows beauty in simplicity. Its professional cameras enable you to take natural and sharp pictures even in the darkest environment. The beauty mode highlights the best features of the owner in every selfie.
112 Perguntas Visualizar todos
Why motion control page does not open?
When I want to go the setting>motion control, this page doesn't open and I only see a white page. I think this error is due to the model No. and build No.;
Model No.: hi6210sft
Build No.: BalongV100R001C50B311
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Try the following:
1. Make a backup of your phone using the phone's backup feature.
2. Perform a factory reset on your phone.
3. Once completed, check to see if the motion control page is now available.
If not, then perhaps you are right.
4. If it is available, restore your phone using the phone's restore feature.
5. Once phone is restored, check to see if motion control page is available.
If it is, perhaps there was something wrong with the OS that has now been reset.
If it doesn't work again, perhaps there is a downloaded app that is causing the problem. Finding out which one will be the hard part.
Esta resposta foi útil?
Pontuação 3
4 comentários:
Really, the motion control feature does not work from the day I bought it and I only see a white screen. Also I try factory reset, but it does not work.
por
Hi,
OK if that is the case, check the warranty period of the phone and if still valid, consult the warranty section of the User Guide as to what you have to do to make a warranty claim for repair or replacement. If you can't find the User Guide , go online to the manufacturer's website and search for 'warranty.
por
Thanks for your answering. I ask some technicians about this problem; they said that these model number and build number are not complete and correct.On the other hand, the firmware of the phone must begin with 3 letter such as ALE. So I think that I must a method to flash my phone to the correct package. But I don't know enough how to do this.
por
Hi,
Found this, hopefully it may be helpful to you. http://huaweifirmware.com/huawei-p8-lite
por
Adicionar a sua resposta
Masoud Kamyab será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,249
