Activation without baseband no imei
So my iPhone hasn't got imei, i cant activate it, is there any tool do this without imei? Thanks
Esta é uma boa pergunta?
No. There is no way you can bypass activation without an IMEI number. The baseband IC is most likely busted and it isn't a DIY fix unless you're familiar with reflowing and reballing logic boards.
Check out this thread here:
U601 RF Replacement iPhone 5 Baseband Chip IC U16X
I cannot verify if it's the same chip they use from the iPhone 5 to the 5s.
Esta resposta foi útil?
Just update to latest version and then run checkra1n. after that there are lot of softwares to jump without activation
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 6,207
1 comentário
Did it get lost or just fall out?
por mayer
