Ir para o conteúdo principal
Distribuído pela Verizon, o Ellipsis 7 é um tablet com Android 4.4 KitKat que possui uma tela de 7" e um processador quad-core de 1,2 GHz. Também pode ser identificado pelo número de modelo QMV78.
How can you help me?
My boyfriend has a table and when he turns it on stay on the one screen that show the table is turning on, but it never changes.
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Please try rewriting this question as it is just not clear.
por
How does one turn on a table
por
@jimfixer
Break dancing: https://www.youtube.com/watch?v=J3SlEc05...
Reach up under the table cloth and caress its legs
Put it in a corner and don't talk to it
por
@mayer the break dancers look just like i did when I fell off the barn roof and tried to get up again , a whole lotta fallin back down bouncin off my head and floppin over.only difference is these guys walk away lookin smug i spent a week in the hospital
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi Brandi,
I think this was what you intended to ask, correct me if I'm wrong:
My boyfriend has a tablet and when he turns it on stays on the one screen that shows the table is turning on ( the home screen? or maybe the boot-up screen? ), but it never changes.
If your tablet is stuck on the boot-up screen, try these few tricks to get it working again:
  1. Are you sure the tablet is fully charged? Try turning the tablet on while it is plugged in to a working outlet. You may want to wait to turn it on to give it time to fully charge.
  2. If you know the device is charged, but still doesn't start, consider doing a hard reset to restore the device.
If your device turns on, but doesn't load properly use the directions at this link.
If your device stops responding entirely, follow the directions at this link.
Remember, a factory reset will clear all the data from your device! Good luck and let us know if this works for you.
Esta resposta foi útil?
Pontuação 2
1 comentário:
@kelsea - Very unassuming, demure and unabridged answer . Maybe we need more females of quality like you on the site to help keep the heathen male savages at bay. That should be a glass of champagne in your hand not a toy. It would appear profusely more apropos. Yes I would "kiss the stone" to tarriance with you. http://www.blarneycastle.ie/pages/kiss-t...
por
Adicionar a sua resposta
Brandi Johnson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 392
