Ir para o conteúdo principal
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
20 Perguntas Visualizar todos
How the heck do I fix the power dongle?
First, thanks for the site - bought a Torx set and got the back of the Evo open. My problem has to do with where the power cord - either a wall adapter or car adapter - attaches to Evo. I don't even know what to call the little piece the adapter slides into. BUT. That particular piece has broken off on my Evo. I can see where it goes, and where the connection points have to meet - but it clearly requires solder to repair. Right now the little metal receptor that is normally IN the phone stays on the end of my power adapter and I use rubber bands and voodoo to keep the charging connection active.
Suggestions? Any way for me to re-secure that thing?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
I noticed you never got an answer to this. Are you still having this problem?
por
Adicionar um comentário
1 resposta
Solução escolhida
I imagine you are talking about the power connector, which can be seen in this photo:
http://guide-images.ifixit.net/igi/5WFTB...
... bottom right, immediately below the vibration motor.
It's a surface mount component. If the board where it connects, and the loose power socket, are both undamaged, it probably could be resoldered back on with a hot air gun and a lot of care, much like soldering in SM IC's. A soldering iron will not be able to do this, it will just mess everything up. If you don't have the tools to repair this, a good repair shop could do it for you.
err, here is an amateur showing how it's done.
http://www.youtube.com/watch?v=yhhLyxkTV...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Rena será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,464
