Ir para o conteúdo principal
LG Power Tracfone, ran on Android's 5.0 Lollipop platform with a 4.5" FWVGA Display, Model (L22C).
17 Perguntas Visualizar todos
Pergunta encerrada
How can I make my charge last longer?
Whenever my phone is charged and then I go about my day or start using it, it seems to burn the charge faster than it should. Does anyone have any idea why this might be or ways to help make my battery last longer?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hey Andrew,
This is a common problem. Your phone may not be holding a charge because your battery has overheated. To fix this try removing your battery and letting it sit out for roughly 15 minutes to help cool it down. If this is not the cause it may be that you are running too many apps in the background, in which case you should try closing them and seeing if that helps. If this does not fix your problem try heading over to our troubleshooting page and looking for other causes and solutions.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 73
