Ir para o conteúdo principal
A Epson WorkForce 645 é uma impressora jato de tinta colorida multifuncional para escritório. Modelo: C11CB86201.
How do you replace the white ribbon?
Hi--
Today I got an error message that my blue ink cartridge was inserted incorrectly. I noticed that the white ribbon on the side of the cartridge compartment was twisted, so I tried to untangle it. In the process, I ended up pulling it out of wherever it came from on the back of the cartridge compartment, and now my printer thinks this is a paper jam. Is this fixable and if so, how do I fix it?
Thanks!
Update (03/08/2016)
Imagem
I think this will post the photo
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Post a couple of photos if you can.
por
Hi--here's a picture showing where the white ribbon is tangled (and it was wrapped behind, before I messed with it).[image|774623]
por
Adicionar um comentário
1 resposta
Solução escolhida
This video shows that cable and its insertion point: https://www.youtube.com/watch?v=9D2uYopO...
UPDATE 5/4/20
This link may also help:
https://www.youtube.com/watch?v=IszUNL7z...
Esta resposta foi útil?
Pontuação 4
3 comentários:
Thanks so much! I'm not sure if I'll do this and try to fix it, or just replace the printer. Though I think if I had been more patient with the problem, cleaning a print head would have been the right solution. Thanks for your help Mayer!
por
Good afternoon, I have the exact same problem as this and need to find the cable insertion point, however the video from the above answer now does not work. Can anyone help please?
por
I have same problem too
por
Adicionar a sua resposta
Meghan Stevenson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 2,174
