Ir para o conteúdo principal
Lançada no Japão a 12 de Dezembro, 2004, na América do Norte a 24 de Março, 2005, e na Europa a 1 de Setembro, 2005.
Number of problems with my PSP 1000.
Here's the deal: a friend of mine was just going to toss out his PSP, but I convinced him to let me tinker with it, to see if I could fix it.
The battery has difficulty holding a charge.
The nub/joystick is non responsive and has sporadic movements.
The D-pad seems to want to gravitate the curser down and right.
Any suggestions on how I can fix these issues? Or is the system too far gone?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
why my psp is slow when playing video
por
Adicionar um comentário
3 respostas
Solução escolhida
You might be able to solve the D-Pad issue with the PSP Button Guide.
It is a really old hand console, so the battery should be dying by now. Unless you found another battery, it'll need to be cabled to the wall.
Maybe try dusting out the joystick when you go in to clean up the D-pad buttons and see if that works?
Esta resposta foi útil?
Pontuação 6
man your psp is awsome its almost like new all you have to do is open your psp and take out the joystick (but remove the round top before opening it) and take out the small black piece thats under the round top
then place it properly back into its place
Pontuação 1
I can do 2 for you
Imagem de PSP 1000 Botões
Guia
Substituição dos botões do PSP 1000
Nível de dificuldade:
Fácil
15 minutes
Imagem de PSP 1000 Bateria
Guia
Substituição da bateria do PSP 1000
Fácil
1 - 3 minutes
Pontuação 0
4 comentários:
yeah, but you are almost a year to late ;-) and its the same answer.
por
there is no late or early
por
but it's the same answer as above, so you have not given anything new...
por
well 1 thing.the battery
por
Adicionar a sua resposta
Colin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Ao todo: 8,429
