Why is my device not recording any messages?
When I miss a call, the device will not record or save any of the messages people leave. What should I do?
Esta é uma boa pergunta?
Make sure the answering system is on. ANS ON light on the telephone should be on. Make sure the memory of the answering system is not full. If there is a fax machine connected to the same telephone line, try disconnecting the fax machine. If that
solves the problem, consult your fax machine documentation for information on compatibility with answering systems
Esta resposta foi útil?
Hi @wgerome ,
If you have an AT&T CL4940 telephone, (you didn’t specify the make or model) here’s the user manual.
Go to p.40 to view how to delete the old messages from the phone’s answering system.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 1,034
2 comentários
can not get the message recorder to record a message when phone rings can not set up
por kenneth kurio
what is the long press screen? I have no msg’s and says I have 49 missed calls but my memory is full, no one can leave a msg, how can I delete those?
por will
