Ir para o conteúdo principal
Lançado em 28 de julho de 2014, o Samsung Galaxy S5 Mini é um celular que possui uma câmera traseira de 8 MP, tela de 720p, sensor de impressão digital e resistência à água. Ele tem uma tela maior, maior autonomia da bateria e uma câmera atualizada em relação ao seu irmão mais velho, o Galaxy S5.
S5 Mini Screen issue "Shows static"
Hello,
I just replaced the entire Lcd/Glass/touchpanel with a new kit. Everything went fine until I switched on the device. Everything seems to be working OK :
- Phone starts up
- Welcome sound
- Is recognized and reachable via USB connected to PC
However the screen does not function correctly. It is like static on an old TV set. (See picture) I tried several times to gently press on the screen connector and such but no difference. Any ideas ? Many thanks for your help !
Tony
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Had this issue once with a HTC One M8 new screen. Turns out it was faulty. Luckily your phone isn't damaged as this has also appeared on a Samsung Galaxy S3 when it's charger port was changed using the heatgun method.
Almost certain the screen is at fault as the phone still functions, just the screen not working.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Hello Ben, thanks for the reply. That is what I suspect as well. However I saw some other posts on internet saying it was a badly attached connector. I repetedly removed and inserted the one but same result so yes probably the display is faulty.
Kind Regards,
Tony
por
πως το διορθωνουμε αυτο το ποβλημα?
por
it could be the screen.. but i also had issue with one.. the fault rather tends to be a software issue... i was brought back to normal by flashing (not factory reset).
Pontuação 1
2 comentários:
how do i fix this problem?
por
by flashing it with Odin
por
Adicionar a sua resposta
tonyknors será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 28
Ao todo: 2,232
