Ir para o conteúdo principal
A Samsung NX2000 é uma câmera digital smart com um flash externo removível, lançada no final de 2013.
Why is my flash not working?
No flash is being produced even when I try to turn the camera on and off.
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
My flash works fine in Auto and Expert modes, but it doesn't seem to work in Smart mode.
por
Adicionar um comentário
1 resposta
A simple solution to your question will be that you have to first turn off the camera and then proceed to remove the battery and memory card from the camera's hardware. After waiting a few seconds, reinsert both components and restart your camera and then make sure your camera is set to Auto Mode. Press on the shutter button to ensure your flash is producing a flash. If it is not, then you may need to charge the battery to your camera.
Hope it helps
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Katarina Raic será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 18
Ao todo: 1,999
