Why did machine stop making steam?
Machine lights up but no steam comes.
Esta é uma boa pergunta?
If the machine is not warming up (feel the top of it) then it could be your heating element or the thermal fuse (both signs of overheating). If it's getting warm/hot and you can get water to flow from the brewhead then you probably just have a plug in your steam wand or valve.
Esta resposta foi útil?
You seem to be the Barista guru. +
+ I bow before your knowledge of this machine ;-)
What is the model/name of the thermal fuse?
It's a 152C thermal cuttoff or thermal fuse, no particular make or model is required. Googling "G4A01152C" should find you some options.
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 13
Ao todo: 2,643
2 comentários
add water or give us more information.
por mayer Compartilhar
Haha, nice one mayer ;)
Replace broken heat element, or clean filthy steam tube is also possible fixes..
por rousp Compartilhar
