Ir para o conteúdo principal
Dual-band, 802.11ac, 13-antenna router launched by Google and TP-Link in September 2015.
What if my OnHub router has a weak WiFi connection?
My device is connected to the internet but my WiFi connection is weak. What could be causing the weak connection and how could I fix it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
A weak wifi connection could be caused by local interference from surrounding metal objects, or by damage to the OnHub antenna array. Move any metal objects away from the OnHub device. If the problem persists you may need to replace the antenna array. Refer to the troubleshooting page for more information on fixing this problem.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Eric Tiraco será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 239
