Why will the speaker not charge?
I have been using the charger that came with the device but it is no longer charging the speaker.
Esta é uma boa pergunta?
Try changing the charging cable. If this does not work, there could be an internal problem with the power socket.
Esta resposta foi útil?
Thank you. Not sure why the first cable didn't work. It works fine to charge other electronics. But I switched the charging cable and it is charging now. Yay!
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 891
