Why does the sound come out weird?
Whenever I try to play music the sound comes out muffled and funny. I’m unsure exactly what is wrong. What can I do to resolve this issue?
Esta é uma boa pergunta?
The most likely cause of this problem is probably due to the speakers either being dusty or
broken, or a poor connection between the phone and the speaker. First and foremost just check and see if the device has a good connection by keeping the phone nearby and clearing obstructions between the two. If that works then the issue should be all set.
If it is the speakers themselves causing the issue, first try to play music through the speakers and see if one is broken. If there isn’t a broken speaker then it may just be a dirt buildup on the surface of the speaker. If there is a broken speaker then the speaker will have to be replaced.
If there are further issues with the sound quality I suggest checking the troubleshooting page for the speaker in order to find the cause of the problem.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 32
Ao todo: 3,031
