Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
stuck in activation screen. Sim says searching with/without a sim car
I've tried recovery mode, dfu mode. But after the reset it still says searching. The clock was wrong so I put the correct time on it by going to iTunes and setting the time on my computer. But that was also not the solution.
I'm stuck in activation screen so I can't reset network settings.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Have you tried connecting it to wifi?
Esta resposta foi útil?
Pontuação 1
3 comentários:
Yep, multiple. I even tried calling 911. It says call failed as soon as I hit dial. (That's with a sim card).
por
Could this be hardware?
por
Try disconnecting then reconnecting the battery
iPhone 5c Battery Replacement
You don't have to remove the display assembly, you can just lift it up and then disconnect/reconnect the battery
por
Does the device have an IMEI? If you press the "i" at the activation screen, do you see the imei of the device there? If not, you have a baseband issue. If so, try activating via the computer, as this could be a time bug (fairly common)
If the device does have an IMEI, and the time is correct, but you get the "sim card is required for activation" message, the issue is in relation to the sim reader or something on the board connected to the sim reader. You can find a link on my profile to locate someone close to you to diagnose/repair the device on a board level
Pontuação 1
2 comentários:
The IMEI number does not appear. How would I fix this. I've tried activating through the computor. So it is a baseband issue?
por
Definitely a baseband issue (sorry, reclaimed my old account so still the same guy here)
You will have to send it to someone for board level diagnosis. There's a link on my profile for a website that should help you locate someone trusted closest to you
por
Adicionar a sua resposta
cameron será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 1,097
