Ir para o conteúdo principal
The Kenwood Receiver model KR-V7070 is an audio/video receiver produced by Kenwood Corporation, a Japanese company that designs, develops, and markets car audio systems, hi-fi home and personal audio systems, professional two-way radio communications equipment, and amateur radio (“ham”) equipment.
13 Perguntas Visualizar todos
My left side tweeter or satellite is not working, anyone know why
The left side tweeter does not make noise but when flipped and the satellite is on the right side it works so the problem must be with the stereo. Anyone got an idea to help
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@po50 just to clarify. Do you have any output from the left side?
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is a link to the service manual for your receiver. The download option (scroll down the page to see) changes from processing to get manual when it is ready to be downloaded.
http://elektrotanya.com/kenwood_krv7070.....
The image shows the relevant part of the circuit.
You will notice that there are 3 relays A, B and S which need to be operated for the sound to be passed through to the speakers. These are protection relays, controlled by the microprocessor (on leads A sp, B sp and S sp), which release if a problem is detected on the output of a channel so as to protect the speakers from further damage, (and maybe even to prevent a fire!).
Firstly you will need to determine which relay A or B (I assume and hopefully they are in a clear plastic case which makes it easier to see) is released. After that you will obviously need to determine why.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Billy McCarthy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 236
