Ir para o conteúdo principal
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Perguntas Visualizar todos
Display lid opens to easily after putting it back together.
After replacing the inverter board and putting the computer back together, the lid opens too easily now.
The two hocks go perfectly into the base part when closing the computer. But the display easily opens, I don't even need to press the button. It seems that the pull (tension) of the Display lid is stronger than before i took it apart and put it back together.
Have I missed something, when I was mounting the screen back in? Do i have to twist the springs on both ends or so? What causes that tension in the screen.
I think its normal to have a bit tension, so that the screen jumps open as soon you press the button, but in my case it's just too strong.
any help appreciated.
thanks
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
There's magnets in the front edge of the bottom case that "pull" the hooks down and into locking postion. Did you move/remove them?
N.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
markus será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,380
