How can I replace the BA97-03985A touchpad?
Is there a guide how the touchpad (part No BA97-03985A) can be replaced?
Esta é uma boa pergunta?
The replacement is really simple: just remove the battery (see Substituição da bateria do Samsung ATIV Book 9 Plus). The touchpad is mounted below the battery with 4 screws (you need a really small phillips screw driver). The spacers (and also the mounting plate) are fixed with adhesive tape and can be removed (by gently pulling) from the old touch unit.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 708
