Ir para o conteúdo principal
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
20 Perguntas Visualizar todos
How much does it take to buy a new screen 3ds
I sat on my ds how much does it take to replace a screen
Update (02/18/2016)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Depending on which screen you broke and how ambitious you are the screen repair tutorial is here Nintendo 3DS XL Touchscreen Replacement
and the replacements for them are here
Nintendo 3DS XL Lower LCD
[produto vinculado ausente ou desativado: IF258-025]
Hope this helps
Imagem de Replace an LCD located on the bottom portion of the 1st Generation Nintendo 3DS XL portable gaming console.
Produto
$24.99
Esta resposta foi útil?
Pontuação 4
5 comentários:
Upper screen
por
so then you can purchase the screen for about 25 dollars and follow the guide in the answer above to fix it. If you want someone to do it for you then you should check your area for repair services near you
por
So I took apart the bottom and replaced the screen but now my select button does not work
por
You may want to take it apart again to check the connections on the buttons. something could have come apart when you were putting it back together
por
ok thanks for that I will check
por
Adicionar a sua resposta
Cody Rozema será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,743
