Ir para o conteúdo principal
Modelo A1418 / Meados de 2014 / Processador Core i5 de 1,4, 2,7 e 2,9 GHz ou Core i7 de 3,1 GHz
No backlight screen is dark
My iMac is A1418 2013 MF883 LM215WF3 (SD)(D1) 21.5".
I installed new screen display and have same issue
I shine a flashlight at an angle at the display and see the faint image of the desktop and icons. How do I fix the backlight?
Which is it? The CFL's or the power inverter on the iMac 21.5" 2013 model.
Thanks
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Pergunta mais útil
This model uses LED's for the backlight and the power is supplied via a ribbon cable from the logic board.
Review this IFIXIT guide: iMac Intel 21.5" EMC 2805 Display Replacement. Jump to Step 20. Make sure the cable is correctly inserted.
Use a magnifier to inspect the pins of the cable and the socket as they could be damaged. If they look OK, you'll need to do a detailed inspection of the logic board as something has likely blown.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Thuan Tran será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 1,467
