Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
O Moto G 3ª Geração (também conhecido como Moto G3) é um smartphone lançado pela Motorola em julho de 2015. Ele serve como uma alternativa econômica para os smartphones carro-chefe da Motorola (Moto X). Conhecido nos EUA como XT1540, com dual SIM e versões Turbo em outros países.
85 Perguntas Visualizar todos
Replacement LCD screen flickers
Hi
I have a nearly new Motorola Moto G 3rd Generation that I dropped and smashed the screen. It was fully functioning, but the front glass was shattered.
I bought a replacement screen / LCD / digitizer assembly from eBay and installed it. Initially, the screen appeared OK, but then started flickering at about 2 - 3 Hz. The screen appeared dull, but that is probably due to the flickering. It now consistently flickers, though is OK for a second or so on power up.
I performed a factory reset, but that didn't fix it.
I contacted the seller, who recommended I clean the contacts and try to seat the screen cable again. I've tried this a few times but it hasn't improved things.
Is this a defective screen? Note: I didn't disconnect the battery before replacing, because you can't get to the battery.
Many thanks
Mooncat
Esta pergunta é pertinente?
Pontuação 0
Comentários:
Did you find a solution I have the same problem! Thanks
por
Adicionar um comentário
Kit de pontas universal para chave
112 bits for every fix.
Upgrade Your Toolbox
1 Resposta
If you did your replacement correctly (and it sounds like you did) and you have already cleaned the contacts and reseated the cable several times, it does sound like a display gone bad. Hopefully the eBay seller gave some sort of warranty on it. Otherwise you need to pick up another display and make surfeit has at least a 30 day warranty (that starts the day you receive it, not the day the send it, in case of longer shipping time, like if getting from China or Hong Kong).
Cheers!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Simon Williams será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,216
