weird screen isseu after screen replacement
Dear,
I repair for living , so i have an Hp slate 7 here for screen replacement.
i only replaced the digitizer not the full assembly.
Now i got this weird $@$* problem with the screen, probably this is weird for you all...
So i did the repair perfectly i power on the tablet no problem...
trying some things to test the new screen again no problem..
Tablet goes in 'standby' i power it on again and now touch screen wont do annything.
So checked the cable removed it and re-installed it , i power tablet on test touch screen... no problems
tab goes in standby and then touch wont work...
anny1 had this problem before? maybe with other tablet/phone?
UPDATE: Reconnecting the batterie makes touch screen work again till it goes in standby.
Esta é uma boa pergunta?
Hi,
Does it work OK with the charger connected and on? If so, look at the battery, it may be failing under load.
por jayeff
