Ir para o conteúdo principal
O tablet ProScan PLT7223G, fabricado pela Curtis International, é um tablet básico com Wi-Fi destinado ao uso pessoal ou profissional.
Why won't my tablet charge?
-I have tried plugging in my charger with the tablet to several outlets in my home but it still won't charge.
-I have tried replacing my charging cable and wall adapter but that doesn't seem to be the issue.
-I have attempted the factory reset but that didn't help.
I was wondering if it could be an issue with the charging port or the battery itself. Any Ideas?
Esta é uma boa pergunta?
Pontuação 4
1 comentário
My tablet with not hold a charge. Charger gets warm after few minutes
por
Adicionar um comentário
3 respostas
Solução escolhida
The problems may caused by a broken charger, dirty charging port or faulty charging port. To fix the problem, check the troubleshooting page for not charge part.Proscan Will Not Charge
Esta resposta foi útil?
Pontuação 4
Pergunta mais útil
Hard to say exactly what it is, without looking at it, but my iPhone had the same issue and it was differently the charging port. I had to have it at a specific angle to catch the charge. It would seem to be an issue with the port, where a battery would slowly hold less and less of a charge before not holding any charge.
Pontuação 4
Your iPhone had to be used in a Angeles
Pontuação 0
Adicionar a sua resposta
Daniel Hernandez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 4,697
