Ir para o conteúdo principal
Repair guides and support for Apex.
How do I get my camera to take pictures front loading
when I open the camera it will only take pictures in reverse. I cannot figure out how to take a picture of someone standing in front of me.
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
3 respostas
Solução escolhida
HI,
You don't say the model number of your tablet. A lot of tablets only have one camera which is usually facing the user, (used for when you "Skype', video call or take selfies - like an inbuilt webcam on a laptop). You should be able to locate it by turning on the camera app and then seeing where it is, by looking at the angle of the picture of yourself. Once you have found what the lens looks like if your tablet has two cameras there should be a similar lens to be seen on the back (non screen side) of the tablet.
If you cannot find it, unfortunately your tablet has only the one camera (check your User Guide to be sure) and the only way to take pictures of what is in front of you is to turn the tablet around and hope that you get the correct picture 'in the frame',
If you do have a second camera there should be an option in the camera app settings to select the front or rear camera.
Esta resposta foi útil?
Pontuação 4
Make my camera take front loading pictures
Pontuação 3
I cant take a front loading pics only back camera works
Pontuação 2
2 comentários:
Hi,
What is the make and model number of your tablet?
por
Galaxy 7 Samsung phone
por
Adicionar a sua resposta
Tammy Davidson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 3,810
