Ir para o conteúdo principal
O Nintendo 2DS é um dispositivo portátil de jogos desenvolvida como uma versão de nível de entrada do Nintendo 3DS com hardware quase idêntico, mas sem a função de ecrã superior 3D.
20 Perguntas Visualizar todos
Why my 2DS does not open?
I have a 2DS and when I power it on the blue light turns on but the screen still remains black. After some seconds it makes a wierd noise and turns off completely. My brother says that it has been exposed to water . Any ideas on how to fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
This is a complete guide for teardown and troubleshooting and can guide you through your fix
Nintendo 2DS
Hope this helps
Esta resposta foi útil?
Pontuação 2
Put in rice for a day
Pontuação -2
7 comentários:
Rice is a food not a tool
por
But if it gets wet it will soak up all the water
por
@Cozy Rozema, Rice is absolutely useless. It will not remove all humidity, it will not prevent corrosion, it will not remove liquid between components and it will not prevent short circuits. Using Rice as a desiccant is the equivalent of doing nothing.
por
You're Both Right - Rice is a fine opening move for consumer water removal, but OldTurkey has a point, it's not going to solve your problems; disassembly will be required.
por
@alinorne Kevin - Rice as a desiccant is an old wives tale. Even if you boil it, it only soaks up 2X. Unboiled all it does is make a mess. Your voracity as an answer giver is at stake here, do the research!
por
Exibir mais 2 comentários
Adicionar a sua resposta
John Hatzis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 317
