Ir para o conteúdo principal
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 Perguntas Visualizar todos
78 mercedes 280E 2.6 m110 I6: difficulties running in the morning
When starting in the mornings will start up fine and idle rough for a 10-15 minutes and during that time acts like the engine is flooding if you try give it gas. What's going on?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
The CIS system on the M110 engine uses a separate electronically controlled cold-start valve. It is basically one single fuel injector that sprays into manifold, enriching mixture. Device is controlled by a thermo time switch, which turns on power to the injector. If the injector leaks or runs too long, and overly rich condition exists causing poor idling and greater fuel consumption (poor mileage). Check thermo time switch by unplugging electrical connection at cold-start valve. If rough idle condition persists when power is disconnected, injector is likely leaking or spray pattern is diminished (caused by a dirty nozzle). It is more likely the injector is faulty than a fault of thermo time switch exists.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Paul severance será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 866
