Ir para o conteúdo principal
The McCulloch MC1275 is a heavy-duty canister steam cleaner that uses ordinary water heated to over 200 degrees Fahrenheit to clean and sanitize a wide variety of surfaces.
Is there a way to replace the hand hold nozzle part.
I lent my brand new MC1275 to a friend who returned it broken. The white plastc part that pops into place when you attach the long tube is missing and when I went to use it s
the tube did not snap in. My theory is that all that steam came oozing out of the whole top of the handle because it was not sealed. Now I have steam vapor even inside the on/off switch. I am afraid that all that steam inside if the body of the unit will effect the wiring and even rust. Is there anything I can do to rescue it or is it toasted??
Is there some place near San Diego t that services these steamers? I want to act as quickly as possible to prevent further damage. Is it even possible to replace the handle???
Patricia Simon
Esta é uma boa pergunta?
Pontuação 0
1 comentário
My canister streamer MC 1275BB is
new .Used app 2 hrs., though not consistently, now it will not get hot. It will get warm, but it certainly won't get to the 200 degrees thats advertised. Its virtually useless. What can I do, how do I fix this?
por
Adicionar um comentário
1 resposta
Solução escolhida
You can get parts here: http://www.mccullochsteam.com/product-su...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
patriciaannsimon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 53
Ao todo: 4,562
