Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Weak WiFi after I replaced the screen
I was so proud that I replaced my screen on my own, done everything right, followed the guide to the T. Only thing is that after the screen was replaced, I wasn't getting any Wifi in range, I moved closer to the router and then it connected perfect, phone signal reception seems fine, just now for the Wifi only works when I'm beside my router takes the whole mobile out of mobile. Can any advise what I done, hit a cable or done something that I can reverse the problem. I need Wifi!! Thanks so much!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
As seen in the picture above, the ear piece has a pin going on to the wifi/bluetooth antenna below it when the screen is closed. The part that touches on the antenna is the little gold almost rectangle part of the antenna inside the phone. Make sure these two parts are making contact.
Esta resposta foi útil?
Pontuação 1
Same issue here unfortunately :(
I’ve double checked and cleaned the ear pieces contacts with no luck.
Would it worth to remove and reinstall the ear piece? It seems like a contact problem, since I don’t know how the WiFi antenna could be damaged while working on the screen (I’ve also replaced the battery)
The spare part is quite cheap, but I would have to disassemble almost all the phone in order to get access to it
Pontuação 0
Adicionar a sua resposta
Gavin McEntee será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,339
