Ir para o conteúdo principal
Lançado na América do Norte em novembro de 2006, o Wii foi o primeiro console de jogo da Nintendo a oferecer suporte direto à conectividade com a internet, permitindo tanto jogos online quanto a distribuição digital de jogos e aplicativos de mídia através do Wii Shop Channel.
Fix cracked wii remote front
I cracked the wii remote front infrared panel while bowling, now it doesn't point. Can this be fixed? All other functions are still working.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
5 respostas
Pergunta mais útil
The tri-wing needed to open your remote is also available in iFixit's driver kits.
[produto vinculado ausente ou desativado: IF145-022]
[produto vinculado ausente ou desativado: IF145-028]
Esta resposta foi útil?
Pontuação 2
1 comentário:
You can try just unscrewing the case and removing the front cover and see if that helps. The front cover is just a filter that only passes infrared light (and keeps dust out). But if you damaged the sensor inside, then you'll need a new Wii remote. To unscrew the case, I believe you need a tri-wing screwdriver, which you can get at Ebay. If the sensor is damaged, you can sell the remote to a hacker who only needs it for the accelerometer.
Pontuação 1
This is what I did to my remote and it works perfect http://howtofixstuff.blogspot.ca/2013/08...
Pontuação 0
The front of the wii remote had a cracked screen because my older sister or brother and me were playing just dance 1 2 3 or 4 she or he kept on hiting it out of my hand. XD is that your problem.
Pontuação 0
Follow a guide for your wii remote, but before that, make sure you buy a replacement case/screen.
Pontuação 0
Adicionar a sua resposta
Val será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 23
Ao todo: 6,832
