Ir para o conteúdo principal
iFixit uses cookies to enhance site functionality, analyze traffic, and personalize ads. By using our site, you agree to our cookie use and Privacy Policy.
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
How to fix the left bumper
My left bumper feels kind of stuck in it and it won't register unless you hit it really hard. How can i fix this?
Esta é uma boa pergunta?
Pontuação 17
Adicionar um comentário
11 respostas
Pergunta mais útil
Sounds like the bumper may be broken in the controller, but try to clean it out in case something got stuck in there causing issues with the contacts. Bumper Panel Installation. Worse comes to worse you may be able to pick up another broken controller on the cheap for spare parts.
Esta resposta foi útil?
Pontuação 7
Related Parts and Tools
Shop all
i think that your bumper isn't touching the micro button... just take thin cardboard or paper with double sided tape on half of it. put that on the analog stick inside cover. it worked for me. or get spare parts
Pontuação 5
1 comentário:
This concept worked for me, but I used Uhaul brown moving tape (just happened to have some in a home repair box). I cut a small square that was about 1/8 inch by 1/8 inch. Painters tape works well too.
por
I had the same issue and I just put a small "mound" of glue on the micro switch. I let it dry and then put the controller back together.
All this did was make the micro switch a little longer so the bumper could reach it.
Pontuação 4
1 comentário:
i have to do this, i was playing dark souls 1 and my attack button (RB) isnt registering well the input, i had to press it very hard and some times registers 2 inputs, guess is almost dead, any microswitch will do the trick if i try to replace it or has to be a specific one?
por
Look at the front of the control cabinet. In the part where it rests on bumper, there may be attrition. Also the micro-switch may be damaged
Pontuação 2
There is a gap under the top bumpers that let you take the remote apart. The problem is that when the remote gets thrown or droped that gap will get bigger, the cause is that there is nothing holding that together so when that happens the gap expands and doesnt let you click the top bumper. The button starts to get lose and its hard for you to use it, when the bumper doesnt work or barley works then it makes some gameplay very hard. The fix to this problem is to ether tighten up the screws in the remote or to find a way to sqeeze the gap back to the position that its supose to be in. You can also find somthing to put inside the gap so that your top bumper is set in the right place to hit in the right spot. You can use a piece of paperor a small piece of plastic.
Pontuação 2
1 comentário:
Ive tried this before, many times already actually... to estimate about 5 times of opening the xbox controller. I tried fixing the micro-switch, placing cardboard, yet to no avail... its &&^&^$^ irritating
por
I had a similar problem with the wired controller I use for pc games. I took it apart and, because I'm a lunatic, used my teeth to carefully pull the microbutton closer. The bumper works again, and I'm happy enough, but it's not really something I recommend normal people do.
Pontuação 2
You might have the "no money fix" sitting right in your closet
https://youtu.be/e0A6p9nSYeE
Pontuação 1
The bumpers use ordinary push-button switches, which can wear out after 100k presses or so. If it feels like you have to press it harder than normal, and the problem gets worse over time, the metal contacts inside the button may be wearing away.
It is difficult, but possible, to replace the bumper buttons. Fortunately, the button itself is a jellybean part: search for 6x6mm SPST tactile buttons, and pick a 4-pinned one with a similar appearance to the one on the controller board.
The bumper button is attached to a metal bracket with two tiny plastic pegs: slowly pry them apart. Then, you'll need to de-solder the two joints between the button's legs and the reverse side of the board. To access both pins, you'll need to move the plastic trigger assembly aside by un-clipping it from the board near the bumper button and gently but firmly pushing it up and off the pin. Do not attempt to remove the plastic trigger assembly, because it is connected to a potentiometer which is soldered onto the circuit board.
Once you have removed the worn-out bumper button, you can slot in your new one and solder it on. I also used a dab of hot glue to attach the new button to the old one's metal bracket - if you lick your finger you can press the glue into the gap while it's soft, and hot glue can be removed if the controller lasts long enough to need another bumper button.
You need some desoldering tools, but it's doable.
Pontuação 1
You unscrew it.then take out the spring and clean it.
Next you tale out the (RB) button,clean that piece.
Then you put the spring in first...then put the (RB)button not top of the spring(be sure it shows/pokes out so you can see it.finnaly, screw the pieces back together
How the controller made into 2 pieces,that's why there are screws to hold it in place
For people w/a wired controller try to screw on the screws on tighter
Or unscrew it and fix that thing that gets on the top of the controller
Pontuação 0
1 comentário:
Hey Justin! I think that’s for the trigger, not the bumper button. What you said helped me clean and replace the spring on my right and left triggers, thank you!
When I pulled my controller apart, I noticed there was no spring for the bumper. I’m assuming the plastic was manufactured in such a way so there was “memory” in it, so when pressed and released, the plastic piece returns to its home position.
por
My button won't push wen I try to put it to throw stuff
Pontuação 0
1 comentário:
Sounds like the controller was thrown or dropped. You’ll need to open it up following the instructions above on this page. The plastic protrusion inside the controller probably isn’t making contact with the control button. Try opening it up and putting a small piece of masking or painters tape on the plastic part that touches the bumper button inside the controller.
por
It won’t work for the game rb button
Pontuação 0
Adicionar a sua resposta
Caleb Anserello será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 25
Últimos 30 dias: 151
Ao todo: 115,150
