Ir para o conteúdo principal
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
119 Perguntas Visualizar todos
Why when I insert a sim card the tablet said invalid card
I insert more than one sim card and they are all working on other devise but in my tablet said invalid card
Esta pergunta é pertinente?
Pontuação 13
1 dos comentários
invealid sim card salotion for samsung t217s
por
Adicionar um comentário
5 respostas
Pergunta Mais Útil
Is your tablet locked to a certain carrier? You can unlock your device if its not still under contract then it would be possible to use any sim. the original carrier will unlock for a fee or you can use an unlock service off the internet. Or if your ambitious you can root your device and learn from hack sites how to unlock it yourself . Hope this helps
Esta resposta foi útil?
Pontuação 6
3 comentários:
Can you give some helpful sit for unlocking my tablet
por
How can I know if it's locked
por
this is a site ive used in the past with http://www.code-unlock-shop.com/?AdGroup...
por
Probably it's locked, try another SIM card!
Pontuação 1
1 dos comentários:
I try alote of sim card
por
most likely because your tablet is locked to a specific carrier. the only way to get another sim card to work in htis instance is to unlock it. luckily you can call the carrier and as long as you don't owe money then they will give you the unlock code for it
Pontuação 0
2 comentários:
But how can I enter the cod... tab3 do not have phone keys because it's gust for data
por
not sure if i understand what you are asking. Even if the tablet is just for data often times they still have sim cards. there are a few carriers and devices that do not use sim cards but its still ok. using the imei number you can still unlock it and change carriers. just call the original carrier for the data of the tablet and they will let you know what to do with it and how to unlock it whether it has a sim card or not. I hope that this helps you out. good luck with unlocking it
por
Unlocked Sim involved
Pontuação 0
How can I find my carrier
Pontuação 0
3 comentários:
Hi,
If you still have the original SIM card and the tablet still works using it, look on the SIM card for the carrier's name or logo which is usually printed on the card
por
But I dont2 have my sim card any more
por
@Emily Hollenbach
Please verify the model number of the tablet?
If you go to Settings > Mobile Networks > Network operators if the tablet is locked to a carrier you will only see the one operator name, if unlocked there should be more or the tablet may work with them as well.
por
Adicionar a sua resposta
Waleed será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 21
Duração total: 6,516
