Ir para o conteúdo principal
O ZTE Boost MAX N9520 possui uma tela IPS HD de 5,7 polegadas com 4G LTE e Android 4.1.
Why won't my external speaker work?
External speaker won't work. Internal work's fine. I can hear music with ear buds, I can hear phone conversation as long as it's not on speaker. My ringer doesn't work as well. Hasn't had any water damage. I did have a cracked screen but it was just replaced profesprofessionally.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi,
How long since it was repaired? Was the ringer function working when you got it back from repair? Does the repairer give a warranty on his work? If it has not worked since his repair (how often do you use the loudspeaker function) it seems very coincidental, contact the repairer and ask. The ringer function (not vibrate) uses the loudspeaker so if it is loose or faulty that is probably why both don't work
por
Why no one can hear me but I contacted hear them
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi Faith Randall,
Have you checked the volume setting for the loudspeaker?
Go to :
Menu > Settings > Sound > tap Volumes > slide volume control for Loudspeaker to desired volume.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Yes I did check the volume
por
Adicionar a sua resposta
mark será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 1,573
