Ir para o conteúdo principal
Lançado em abril de 2014. CPU - Quad-core 2,3 GHz Krait 400, GPU - Adreno 330. Tela - IPS LCD, 16 milhões de cores, 1080 x 1920 pixels, 5,2 polegadas. Memória interna - 16 GB, 3 GB de RAM. Sistema operacional Android, v4.4.2 (KitKat). D6502, D6503, D6543
USB Charging Port Replacement
My Xperia Z2's USB charging port is damaged and I'm trying to find a fix online, but I can't seem to find anything useful. I need some serious help and methods on how to do this. Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The Experia Z2 charge port is soldered onto the logic board. You need a solding station, hot air station and a microscope to preform this repair. And the skill and knowledge to preform the repair.
This is not a easy DIY repair, I would recommend taking it to a repair shop that does mico soldering.
Esta resposta foi útil?
Pontuação 5
3 comentários:
helpful...but I also shattered my back glass cover...will removing it for repair render it useless...??
por Compartilhar
sorry, do you know where can I found the charging port replacement for my sgp512??.......thank you.
por Compartilhar
ya i tried that cant do it
por Compartilhar
Adicionar a sua resposta
Syam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 4,584
