Ir para o conteúdo principal
O Xperia Z1 Compact é o smartphone com câmera premium da Sony. Ele é semelhante ao modelo Xperia Z1, exceto por ser menor e mais barato. Seu principal recurso é um sensor de imagem de 20,7 megapixels. No lançamento, as cores disponíveis eram branco, preto, rosa e verde-limão. Este dispositivo pode ser identificado pelo número do modelo (D5503)
Screen not working after replacement
Hello I have Xperia Z1 Compact with a broken screen. I have ordered a replacement screen from ebay. When I connect the screen to the phone and turn it on, nothing happens. I know that the phone works because I hear boot up sound. Also when I press unlock button and then volume up/down keys I can hear the volume change sound. If we assume that the replacement screen is working, what could be wrong with the phone? Is there anything I could do to fix it?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I have a similar problem, i tested the new screen and was satisfactory, however after installing it with the gasket it failed to fire up
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
The LCD ribbon cable could have been damaged during installation. Make sure the lcd connector is connected prperly. You might have a defective part, eBay parts are not always the best choice....
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for the answer. Unless the ribbon was already damaged I doubt I damaged it. Connector is easy to access and I was gentle. I was wondering what chances are there that there is something wrong with the phone itself. For example that metal panel below the display (is that heatsink?) seems a bit detached now. Could a connector itself be a bit detached from the board?
por Compartilhar
Adicionar a sua resposta
Ivan Savu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Ao todo: 1,367
