Ir para o conteúdo principal
iPhone 5 Pentalobe Screws Spinning
I have refurbished an iPhone 5 into a "6 mini" housing. Done a few of these, no problems. Had to change the battery in one as it could of done with a new one, one of the screws wouldn't come out and now it spins (so not stripped) but turns to a certain point then clicks
any suggestions? don't really know what else i can do.
no access to the screw other then a screwdriver.
i've used a magnet to make the screwdriver stronger but it didn't work
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Try prying up on the screen just slightly as you try turn it out. Sometimes that can push the screw against the edge and get it to come out.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Well. The issue is that the threads of the screw are stripped. Inside the device. So, you could try super gluing your driver to the screw end, and seeing if you can pull it out, probably quickly
Pontuação 1
1 comentário:
That would just make it worse, thanks though.
por
Adicionar a sua resposta
James Carter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 462
