Ir para o conteúdo principal
Part of the 15 series in Dell’s Inspiron notebook line, the 3520 model was released on October 18, 2012. The Dell Inspiron 3520 is a 15 inch laptop that is both affordable and capable of meeting a variety of needs.
20 Perguntas Visualizar todos
Problems with wland drivers
I can't make wifi works on this computer. I installed windows 7, 8 and xp, and in none of them appears as if it wasn't installed at all. Everything started after I upgraded the pc's bios to its A10 version.
I unsuccessfully tried installing the drivers for each os. After that I installed windows 7, then went into the bios and restaured default settings. Then when I turned on the pc the card was automatic installed. Now I have windows 8.1 on it but still I can't install the software for it so I can't use the hotspot or the bluetooth neither turn on the signal after turned off using the keyboard (FN+F2)
This is the card number: NIC PCI-E de LAN inalámbrica 802.11n Realtek RTL8191SE
Esta é uma boa pergunta?
Pontuação -1
1 comentário:
Hi,
Just to verify, is there an option in BIOS to turn WLAN on and off? If it is on what is device manager saying regarding the status of the device (bluetooth as well)? What message are you getting when you try to install the driver software?
Is this the driver (win8.1 32 bit) that you are trying to install http://www.dell.com/support/home/us/en/1...
por
Adicionar um comentário
1 resposta
You need to install the compatible driver, and when you install manually, you can try to run it as administrator. And you can use driver tool like Driver Talent to install drives for you computer.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jrgg1994 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 10
Duração total: 183
